Root post all coustom sounds here.
thevisitor83
This a custom lock screen transformers sound.
Just download the mp3 from phone,use root explorer find the mp3 in your download folder
Copy it,now press back and go into your system folder now go to media/audio/UI and copy the lock.ogg to your sdcard if you like.and their is were you delete the old lock.ogg and copy the new one you download from here.
http://db.tt/3NMZYgUM
This my first post like this hope you all like it.
Visitor831
I made this as a boot sound. I used the lock.ogg above, and combined it with the "Droid" sound.
To use, move the mp3 using Root Explorer to /system/sounds/power
Rename the stock mp3, delete, or save somewhere else if desired.
EDIT: Got the share link, I think.
http://db.tt/5kHMiJpN
Just made a dropbox account now, and I haven't figured out how to get the short link like everybody else does.
https://dl-web.dropbox.com/get/Sounds/MetroPCS_PowerOn.mp3?w=81c9c761
EDIT: To use, move the mp3 using Root Explorer to /system/sounds/power
Just tried the link.. It says i don't belong here and try logging on.. I believe if i remember correct there is a public folder and you also need to get the share link..
Edit: Just looked in the public folder and there is a .txt file that contains this;
The Public folder lets you easily share single files in your Dropbox. Any file you put in this folder gets its own Internet link that you can share with others -- even non-Dropbox users!
Step 1: Drop a file into the Public folder.
Step 2: Right-click this file, then choose Dropbox > Copy Public Link. This copies an Internet link to your file that you can paste anywhere: emails, instant messages, blogs, etc.
That's it! To share your file, just send the link to a friend.
