Help Post Call Lag
samaruf
Has anyone of you noticed this lag on their Moment? After I'm done with a call, it takes almost 30-40 seconds for the screen to return to Call Log. It's very annoying especially if you want to make a quick second call.
What I'm realizing is that this smartphone is truly remarkable and I like to show it to all my friends, but when it comes to making a simple call, there's much left to be desired.
Have you upgraded to CL14? I had that prob a lot worse with CJ05.
Also, I'm not positive if this is related, but in the Data Synchronization settings, I only have Gmail checked. Contacts and calendar I do manually.
I also use Google Voice for all of my calls and SMS.. so, factor that in.
I upgraded to CL14 the first day it was available at my local Sprint Store and it fixed many issues but this lag is still there. I have Google Voice too but don't use it. I'm thinking of doing something radical like resetting my phone to factory settings and keep it that way for a week. This will tell me if the culprit is one or several of the myriad apps that I have downloaded.
I've never had a lag of 30-40 seconds. But, when I finish from a call, I have to wait for the proximity sensor to bring the screen back so I can end the call & make another one. The time it takes the screen to come back seem to be taking a little longer though. And there's nothing to do exept wait. If I press the end button, it puts the phone to sleep, which means that I now have to press the end button again to wake the phone. It's a pain until I adjusted to it.
Mine lags like a mother-father after hanging up as well. Just another problem with this phone we all have to deal with. Best thing I can tell you is to hurry up and wait.... for a possible update. Honestly, with another Moment being talked about, I wouldn't count on it.
The sad part to all this is that if they do decide to push the Moment 2 & let this one slide by the wayside, Sprint won't be willing to give us any kind of a deal to swap to the Moment 2.
