With all the focus on the rooting process itself there seems little clear information on what happens once rooted. What I have discovered so far (for Cyanogenmod7):
1. It took a few moments to realise the lock on screen could be flicked away with the finger!
2. I was not able to access apps at the Android Market or Appbrain. It seems I need to flash a Google apps package to phone.
3. I need to reinstall HTC Sync on my work computer (I did the rooting process from home).
4. Hopefully by then I can reinstall apps from the Market.
5. I need to set up Exchange ---Done!
6. I have set up my two Google email accounts however they do not display under "Accounts and Sync". Hopefully when I flash with the goo-inside.me - gapps downloads that will be fixed.
Current questions that remain:
Can I reinstall apps from the sd card directly? Or, as I have backups from "Mybackup Pro" on both the SDcard and on my PC, can I restore apps from there? This means I suppose I need to reinstall MybackupPro but need to install the gapps first.
Initally a scarey process, but getting more confident now.
Once I get some of the above sorted, I will try to put together a comprehensive list of what to do after rooting - no doubt many will have useful comments to add.
Cheers,
Muzzman
Cheers,
Muzzman
