A arushhsingh Newbie Apr 16, 2011 #1 hey guyz Name the apps which can be accessed without using internet access.
M Marvintheparanoid Member Apr 16, 2011 #2 https://market.android.com/ Look on the 'permissions' tab for an app and it will tell you if it wants to use the internet. Most apps should work okay without internet access, though obviously you will get fewer features/services.
P pankaj16 Member Apr 18, 2011 #4 Strangely, you will require internet to download the apps first Further internet is inevitable considering the purpose they serve and constant updates.
