I got my first post-update BSOD less than 7 hours after the update. Upon removing and replacing the battery, I discover the battery was at 60%, with only a 10 minute phone call and the update while on battery. Not happy so far.
Was your battery calibrated properly? Try recalibrating it.
It had been fine until today. But after thinking about it, I think I remember having battery level issues following previous BSOD. I'll keep an eye on it, but I think this BSOD and the other one mentioned were somehow tied to a rogue process with high CPU utilization and/or keeping the device awake (yet somehow unresponsive).
Some people having BSODs have isolated it towards a program. One of them being SetCPU. Some have said that once removing it they stopped having BSODs. Might need to find that rogue app.
Yes, but you're not going to like what I have to say.
Factory Reset. Run for 12 hours / one full battery charge. Add one of your apps. Run for full battery charge.
Wash. Rinse. Repeat.
That will be the only way to know. ANd even then, you cannot be really sure, because it may not be a single app, but a few apps acting in concert with each other.
If you are running a task manager of any kind to autokill your app, STOP!!! and see if that helps before doing what I outlined above.
Some people having BSODs have isolated it toward a program. One of them being SetCPU. Some have said that once removing it they stopped having BSODs. Might need to find that rogue app.
Since launch day I've had at most 10 BSODs. They don't occur frequently enough for this troubleshooting method the be effective.
One thing I've considered is buying the paid version of System Panel, and setting it up to log running apps, CPU and RAM usage. Checking the logs after a BSOD might reveal the culprit, or at least narrow things down a bit.
0. As in 0 instances of BSODs.
And I've never turned off in pocket detection either.
The only SetCPU I know of requires root-ing.
Is everone in this thread talking about root-ed devices after applying the 5.5.893 OTA?
Root-ing doesn't by itself caue problems ... instead it raised the barrier that allowing potential dumb mistyakes and malicuous attacks to get through.
The un-root-ed solutionis to do what John suggested. After proving that a reset doesn't help ... you don't have much to loose ... do a factory reset and the slowly add applications back and hopefully you will get a failure and can zero in on it.
To prove that the foundation is correct ... run un-rooted slowly installing your Apps over days and if that works out ... root and VERY slowly add priveledged Apps (if you know them).
... Thom
I am not rooted... and neither is my Bionic.
A "catch all" phrase that everyone can identify and search for is better than 10 different wordy descriptions of the same or similar problems which make it difficult to find relevant information.
