Post your Android Desktop
Sorry for being completely oblivious, but is that an app or? Tried searching for it on the market and nothing.
Haha, no worries. I didn't know anything about it at first..
Go here, Java SE Downloads - Sun Developer Network (SDN)
Download the JDK and install that.
After you're done installing that, go Android SDK | Android Developers
and download the SDK for whatever Platform you have and Install that.
Then follow this YouTube - How to Screen Capture your Android Phone?
By the way I've tried this on windows 7 and windows Vista and for some reason it doesn't seem to work. Works perfect on XP however.
I'm running 7 Ultimate 64b and it works great. Screen capture from ddms.bat launcher inside the tools folder works just fine.
I'm running windows 7 64bit too, I was forced to install windows xp virtually in order for this to work. For some odd reason I couldn't install the proper drivers on windows 7, they would install on its own.
Wallpaper is below for you guys...
For the lockscreen clocks its digital world clock, and I've custom made the wallpaper with the "Melbourne.""London.""Germany."
I'm not sure if it will work, but here's my desktop. I chose to make use of all seven screens, and I'm using Launcher Pro.
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
Crossing my fingers, hoping I posted the pictures correctly!
It's called "ToDo List Widget" and it's free on the market. And yes, you can check off items on the widget itself, as well as change the background (although there are a limited amount of backgrounds) and change the font colors.
Cool, will try this out. I'd be soaked if it the list is scrollable! lol I need to post this one on some other threads...I know some members were looking for an app like this :D
Thanks for the info! :D
It is scrollable, by using the small triangles at the top/bottom corners of the widget. Enjoy!
