Post your Atrix home screen
What setting app is this?
Sorry for the delay, haven't been checking the forums lately.
The app is Widgetsoid. After you create the widget you can make it a notification icon in global settings.
I'll show a step-by-step on how to do this. This step-by-step is how to make it a notification icon once the widget has already created.
Access the widgetsoid app:
http://i.imgur.com/YZEjx.jpg
Choose the widget modification option:
http://i.imgur.com/mQIeD.jpg
Select the widget to add to notification dropdown:
http://i.imgur.com/4M04l.jpg
In advanced options, check off the box (circled in red) and it will appear in the drop down:
http://i.imgur.com/ZC5Bo.jpg
When you pull down the notification shutter it'll appear like this:
http://i.imgur.com/MnYcw.jpg
When you click on the notification it will appear as this:
http://i.imgur.com/lXRlX.jpg
Sorry for this is confusing, did it from my phone during my break at work.
My current layout:
It says it took the shot, but then the images are 0Byte, and therefore, can't be oppened.
I tried screenshot it (root and no root).
Maybe has to do with my Rom. I am using CM7 neutrino.
Might have something to do with it. I'm rooted and unlocked. Screenshot it works for me but I'm still on stock blur
love the profiles, some great ideas there .. ive just been sitting pretty with more regular layouts but ill be having a look into some of the ideas - if i can find them :cool:
I am needing help though . Is anyone able to tell me what the shortcuts are called .. for wi-fi, blootooth, gps, brighness ect show just above? Ive deleted them mistakenly and cant seem to re add them???
mucho help appreciated thanks ;)
Search the market for "power control" i believe u will find what you're looking for
What's the weather/clock app? I use Beautiful widgets but I like this smilie face!
And what is your lockscreen in your next screen shot? That is awesome!
That is 4 x 2 superclock from beautiful widgets. Emotisun skin for the weather.
That lockscreen is the Cyanogenmod 7 lockscreen with a wallpaper from flikie.com and an extra ring for launching 3 custom apps (camera, go sms, poweramp)
I was using QQ Launcher but went back to the phone default UI and just customize it a little. Here is what my phone looks like now.
love the power controls (where'd ya get them!!) jadnice, but your batterys not going to last with all those widgets .. why are you running the same office tools/utilities/calcs on two pages?
