Post your battery usage screen shots
CuBz
Android Expert
I thought it would be a good idea to have a thread where users can post screen shots of their battery usage so others can see how long battery is lasting for depending on how much it is used :)
For those that do not know, you can get to the battery stats in 'Settings -> Battery' then screen shot that, then press on the graph and screen shot the graph (to take a screen shot just hold power and home button together) :)
Here's mine from yesterday (extreme use)
On the Galaxy S3 you can also get a screen shot by simply doing the palm swipe motion across the screen...
I'm at work so am unable to attach a screen shot - not quite sure how to attach a screen shot from my phone either, to be honest. But I'm intrigued how you have a cell standby of only 4% after over 13 hrs (unless of course the use was so heavy it was hardly ever put down). I've been at work and my use today has been low. After 9 hrs 20 mins my cell standby is 59%. My battery is only at 80%.
High cell standby is a known issue with the S3. Which firmware are you running?
Hey CuBz,
I like this Idea.:D How do you post your pix like that :confused:
After taking the screen shot I upload them to my photobucket account using the photobucket app, then I copy the IMG tag and link and paste them onto here :)
CuBz,
Thanks for the info:D I don't have photobucket app.
I'll Just attach :cool:
Also I think another good idea would to post or show your screen time. This way we would know that the phone was being used. I do like this idea also. Thanks for for making this thread.
I did post that in the OP but nobody seems to be posting it lol
I have no idea what happened here. It went from 40%+ to 15% in the blink of an eye.
Here's my results from today with moderate usage.
About 30 minutes phone usage.
50 texts
Surfing on the net and Tweetcaster throughout the day.
Ran about a dozen speed tests
I'm rooted using Blazer ROM which is no frills, no bloatware, and a huge battery saver.
Looks like it stopped recording for awhile. The perfectly flat bit is where this seemed to happen. Did you have your phone off for awhile or anything?
Anyways, it looks perfectly fine aside from that hiccup. If you draw a line from where it stopped updating to when it started again, it matches pretty well with the drop before hand.
