Root Post Your Best Tweaks Here... CT Mod/CM7/CM9
I use CT and CM7 and CM9 testing. I've been wondering what are the best tweaks to use on our Prevails that give the most boost for 3G downloads and uploads and system related? I have been reading around on here and everything is so scattered. I thought I would start a thread so everyone can post their best results for mods that
you all are using and which tweaks work best together. As well as newer tweaks and newer versions of tweaks that are good.
Thanks!
My best tweak is to not try to over clock too much on any rom. OK so that isn't a tweak :-). I can get mine to go up to 900mhz but if I stress it with games for 15 minutes or some other intensive app it will reboot.
I keep mine at 864 now and its solid. Better to know what your particular phone will do and not try to over-do it.
I agree with you the tweaks on here are pretty spread out. You have to check back every so often to see what has been going on.
