Post your Droid screens!
Just made mine up. Still kind of a work in progress with sweeterhome preview 2. There is also a screen on the bottom which I didn't capture which just has a picture and a button for all applications similar to the home apps button. Just tried to keep it simple. I don't use the top screen.
Pictures are from top to bottom, Left, Center with one tab, Center with other tab, and Right.
You HAVE to get me this background! She's my absolute favorite!
heres mine nothing special it took all day to figure what i wanted on here and set everything up the way i wanted to and plus i ran out in whats left of my bank account to buy any more apps but 10 hours later enjoy:D
MOD EDIT: Please don't quote large images it lengthens the thread uneccesarily and makes it very hard to read
I have my droid bout a week now. And I do browse this forum every day.
I am finding lots of interesting info here. Thanks
I have been looking for Home ++ from the Droid Market for over 30 mins now and cannot find it. Am I using the search feature correctly?
I search for "Home ++" and come up with over 1200 apps. By the time I go through all these, my battery will be dead. How can I easily locate it.
I also tried to search Themes SmallCaps and I cannot find that either.
Therefore I think I am searchin wrong or in the wrong spot.
Thanks
Thanks
Try home++ with no space in between.
Thanks
Woodstock is correct, take the space out and its the first result. 'home++' Also the smallcaps theme is a SweeterHome preview 2 theme and cannot be found in the market. If you want it you have to install the skins through the SweeterHomw menus on your device..
SweeterHome - Start - sweeterhome.com
Can I get a copy of your wallpaper ;)
When I search on Home++ or "Home++" with quotes, results shows only one app "Flip Clock beta". Opening that it suggests for better animated wizards search 'Home++' which I just did.
I have shut down as well as pulled the battery thinking maybe there is a cache loaded somewhere, but I get the same results.
strange. flip clock beta is from the same developer, so find that in the market and do "view more applications" under "about the developer".
Well Home++ beta comes back with check your spelling msg, or something like that.
As I said in my original post, I am new to this. Is there a possibility that I do not see this app because I have a HTC Eris and not a moto?
BTW when I search on the developer "Intuitit", I only see 2 apps, the fore mentioned Flip clock and Timer
Just scan the barcode in the link I provided and if it comes up as item not found then either your device or your OS is not supported and that is why they dont tease you by showing it...
I did the scan and it came up as the code was not registered or was created from an unknown source. Therefore I am assuming that it will not work on my HTC, but even the cryptic response does not really tell me that.
I have to say, this was a learning experience. Wouldn't have been nice that the doc would say this app is for the Moto? Instead it took me 2 hrs to figure it out, of which I am not 100% sure that is the answer. Anyway enough time wasted.
Thanks to all those who helped.
Its not a matter of motorola > HTC here. Its Android 2.0 > 1.5 ;)
Your flip clock is black, how did you do that, mine is white.. I have the Donate Version of flip clock weather widgets and you can download custom versions, which version is that and how did you do that?
How in the heck do I find Sweeterhome? Is this in the market? or something I have to find online? Can someone point me in the right direction? Also, Can we use springboards with Home++ ? If so how? Thanks guys! Love this website to death! Your phones look awesome, mine is slowly getting there!
10 Character
MOD EDIT: Please don't post images wider than the site. Either resize them before uploading, or post a link
Wallpaper Linkl
She's mine too:D
Its from weather widgets donate and I downloaded skins for the clock and its clock black.zip
She's mine too:D
Got it, awesome, Thanks! Anyone know about the springboards, can we use them with Home++
Is this the smallcaps theme?
