Hey Ninthwonder, I would love to have that wallpaper. any chance you can post a link or the wallpaper?
just download the backgrounds app from the market and do a search for earth... it should show up there...
awesome. where can i find a bigger version?![]()
So I download drocap or whatever it is for screen shots, but when it says shake or whatever to take the pic or screen capture, but it takes the picture with the screen capture program still in it, saying start or stop etc.
And how long does the timer go? Can someone give me some instructions on how to use it. And how to access other screens before it starts up...?
Thanks for the help!
Hit start then your home button and go to whatever you want to take a cap of then shake it. You'll have enough time, but I never tested how long the timer is.
Well my issue is when I shake it and it takes the pic, it shows the start and cancel buttons still...
Once you push the "start" button, you're supposed to back out of the program and navigate to whichever screen you want to take a screenshot of... THEN shake it![]()
Said much more clear than me.
And I looked into the timer function. You hit the menu soft key go to "prefs" you switch "capture mode" to "timer trigger" then when you're back on on the start trigger screen there is a slider bar you can move to select the amount of time you want to trigger.
Dont know, sorry.awesome. where can i find a bigger version?![]()
I also like using Home ++ sometimes, but I like this look.
Two questions. Using GDE non rooted phone how do i take screenies?
and everyone using beatiful widgets for there clock what skin is that for the HTC looking clock?
where can i get the big green battery level indicator on the far right screen?
can you pretty please tell me where i can get that octogon battery indicator, i've looked everywherehere are my screenshots. finally
including some easy step by step guide for an easy "do-it-yourself" mod experience. CHEERS.
It's actually only 5 screens, he just has different stuff open. If you look at the icons in the background, there's only 5 different screens.How did you get ten 10, well 9 screens? Do tell!
here are my screenshots. finally![]()
