Post your Home Screen!
After obtaining root, you can finally screenshot! Post up your homescreens! ;)
https://www.dropbox.com/s/soj4jzrtqu94n0i/2013.02.13-00.11.15.png
PK-YavCFzDRks1DXz031dI39wwfRSA8ZBNhfBVY_0vY
I'm coming from a S2 Skyrocket which was way, way, way better in specs and had 4G! My camera is busted though, so had to get something cheap for now. This will do until my upgrade, and will be good once ROMs get going. Liking it so far anyway!
Lock screen with Holo Locker:
Homescreen with Holo Launcher, default Google Search widget, and BeWeather widget:
Liking the holo locker, I got my fusion 2 after my note broke.
Holo gives it a closer to ics or jb look. Im going to post a video of some cool cm7.2 customization for you guys a bit later.
Lol, I'm surprised you're using a sidebar app too. I'm using Glovebox. It's so awesome on a screen this small.
Been playing some more with mine. The battery life rocks.
Nice setup.
Sidebar is one of the best apps I have used. I was using SwipePad, which is pretty awesome, until I came across a post on xda-developers talking about Sidebar. I tried it, and was pretty impressed.
Glovebox looks absolutely awesome, I am going to try it out.
Thank you for the tip.
I like the widget feature too, kinda remind me of the AOKP feature where you can stick them on the bar.
Very nice what is the theme comprised from? I like the app list on the lock screen.
It's the home screen. :D
Theme is RetroPlus for theme chooser, and then Colourform for HD Widgets for the time and weather. For the app list, I'm using Tagy Widgets, and the icons are from Mianogen Icon for Apex/Nova.
