Post your home screens
mine
i want that wallpaper if its the live one that comes with the driod x. Where did you get that one from. And does my phone have to be rooted?
Nothing special
Pinetrees, though it's nothing special to you, it's amazing to me. I purchased this phone due to my eyesight problems. Your setup is what I need to complete my visualization issues.
Sorry for this but could you tell me the different apps you have here and how you installed them.
Much thanks, Tomween1
That is LauncherPro using the Froyo dock. The weather widget is Fancy Widget, which you can download by scanning this QR code with a barcode scanner on your phone:
OK so admittedly I'm still an idiot! I looked at the free barcode scanners, but I'm miffed, how do I download them? There is no, straight up, DOWNLOAD showing on any of them!
Also is Froyo hard to install and do I need it to add these items?
Thanks again, bewildered ;)
OK, think I have my device laid out the way that is most functional for me... I use four home screens (entertainment, home, calendar, social) and am using QuickDesk as an overlay to get to folders, see battery info, and access power control. Overall this works real well for me personally. I am using ADW.launcher with the the Droid X theme.
Entertainment screen:
Home screen:
Calendar screen:
Social screen:
QuickDesk overlay:
[DT];1281247 said:
I have to ask, what is going on in this screenshot? That looks like HTC Leap feature...are you using a custom rom or is that from something else? I'd really like that on my phone.
Howdy!
That's Launcher Pro. You either double-tap the Home button or "pinch" the screen (like how you zoom an image) and all your home/desktop screens display, then you can select the one you want. Pretty nice way to switch between screens vs. scrolling. I like the idea of having each Home screen fine tuned to a specific function like travel, social networks, general home, etc.
Use a site like appbrain. You can install the apps straight from there. Here is a barcode scanner: Barcode Scanner - Android app on AppBrain
You can also login and create app lists (apps you want to install). Its a very handy and organized way to keep a list of your apps.
Let me fix the colors first!! No, I'm happy to share..
Retro Clock
Simple Calendar Widget
Weather Forecast (by Francois - the free one)
edit: Colors fixed in original post.
Incredible weather app/widget. Tons of options, GPS or manual, seems to be totally up-to-date with weather data, backgrounds, themes, great find!
I realize my colors were funky too and I saw there was an option to 'invert red/blue' which fixed me up.
Here's my weather now:
ill play.
What I cant figure out is how some with LauncherPro have the gray gmail icon. I want that. My red labels icon stands out like a sore thumb
edit: nevermind, found the gray icon :)
When you hold down on the icon and change it, it will popup with use original icon or launcherpro icons. Choose launcher pro icons and choose the mail one. Or whatever matches what you are putting there. You may have to change it and change it back to choose the icon again. Hope this helps:D
Yes, I love it! And your home screen looks great as well!
