Post your MicroSD card benchmarks
sremick
Android Expert
I'd like to start collecting MicroSD card benchmarks. If you have bought a MicroSD card for use in your Captivate, please help out.
To test:
Install the following:
SD Card Speed Tester - Android app on AppBrain
Run it several times to make sure you don't get a fluke low number (like from momentary activity). If your phone is idle, you should get consistent results.
Then, please post to this thread with the following:
Card brand/model
Capacity
"Class" rating
Write speed (MB/s)
Read speed (MB/s)
Although it's not made obvious, the author has updated this app so that on Galaxy S phones it appends sd/ to the test path in order to test the external card (if present).
Results will be consolidated onto CapFAQ.com
A-DATA 16 gb card Class 6
First test: Write 7 mb/s
Read 15 mb/s
Class 6 card
Second: Write 8 mb/s
Read 12 mb/s
unknown class
Third: Write 9 mb/s
Read 13 mb/s
unknown class
San Disk Gig 8 Gig
Write 6MB/s
Read 15 MB/s
Tested 3 times as the App suggested. Scored the same all three times...
Is that good?
Transcend Micro SD-HC
8GB
Class: I do not know/remember.
Write: 5 (MB/s)
Read: 12-14 (MB/s)
I never formatted this card on the Captivate. Took it out of my blackberry and put it in the new phone.
Do I need to reformat it on the Captivate?
I tested two cards. My 8GB is in use, full of data, and I just unwrapped my 16GB. Used the default buffer of 1MB. After seeing the results, I'm a bit concerned about the read speeds. Looks like more people are getting 13+ even with Class 4 cards, where I'm maxing out at 13 with the Class 10 and not even getting close with the Class 4.
Patriot
8GB
Class 4
Write: 4MB/s
Read: 9MB/s
Write: 4MB/s
Read: 9MB/s
Write: 6MB/s
Read: 9MB/s
Kingston
16GB
Class 10
Write: 11MB/s
Read: 13MB/s
Write: 12MB/s
Read: 13MB/s (Suggested Class12 at this point???)
Write: 13MB/s
Read: 13MB/s (Suggested Class12 again?)
SanDisk
32 GB
Class 2
Write 3-4-4-4
Read 10-11-11-10
Just arrived yesterday, loaded it with 30 GB of ghost PC images and then loaded a bunch of other files, tested read and write of those files, everything worked as expected.
Loaded it into my phone and formatted... 31.20 GB
$59.99.
Kingston SDC 2GB (bought ~2 years ago on Woot for $5)
I never paid attention to class, and it isn't marked on the card.
The tests says it may be class 6.
I ran the test thee times, results were identical-
Write 7
Read 9
SanDisk
32 GB
Class 2
Write 3-4-4-4
Read 10-11-11-10
$59.99.
Where did you get it so cheap?
Ebay, Seller from New York I trusted from previous transaction, he must have been feeling out the market because he has since pulled the 'buy it now' auction, here is one of his completed listings TinyURL.com - shorten that long URL into a tiny URL he also threw in a USB adapter along with the SD card reader. If he still had them available I would recommend it to my mom if that means anything to you. As I am sure you know, there are lots of fakes out there, but that doesn't mean they all are. I have been researching for a while hoping to find the promised Samsung Class6 MicroSd card but I just could wait anymore. Didn't want to buy 16 when for just a bit more I could get 32...
On a completely different note and something you might want to consider in your benchmarks, I upgraded to Cog 2.2 B7 last night using the "From Eclair 2.1" steps found here TinyURL.com - shorten that long URL into a tiny URL and here are my numbers...
Write 6-7-7-7
Read 13-14-13-12
I was quite pleasantly surprised as this is now reporting class 6 speed, I even bumped the buffer up to 5MB and still got the same results.
I upgraded from 2.1 which had Unleash the beast v0.2 and RyanOCLF. Backed up my apps to my new card with TiBU, restore went perfectly.
Patriot 16gb Class 6
29.99 at Frys with SD adapter
7/15, 7/15, 7/15
I have a fistfull of movies on it and they playback very smoothly. Media scanning time isnt too shabby either, considering I have about 10 gigs of music on the internal and 12 gigs of movies on the external. Price for phone: 149.99, price for card $30. total, less than 200 for a 32gb phone. Price of 32gb Ip4 $300. Cant complain about that at least!
Sandisk 8gb, class 2, tested 4 times (I guess something was running on the 2nd test), all 4 test were with a 1MB buffer
Write: 6MB/s - 2MB/s - 8MB/s - 6MB/s
Read 13MB/s - 12MB/s - 15MB/s - 13MB/s
The app thinks I have a class 6 card
Yeah, that's not gonna work for me. I've using the leaked Froyo, and even emulating other markets, I can't see it on the market. Fast Install on AppBrain also isn't working for me.
So please, if you wish to help me, send me the APK, as I requested.
W- 6mbs
R- 13mbs
W- 9mbs
R- 13mbs
W- 8mbs
R- 13mbs
I am on Cog 2.2 Beta 2....no problems finding the app in the market.
Try appbrain then
