Post your Nexus One home screens!
Sorry if it's already been asked and answered but how do you get your widget to look exactly like that? Mine is much bigger with the temp underneath the time instead of to the side like yours. The clock takes up the whole top row on mine.
edit: Nevermind. Duh. Smaller Home!
Okay,
I have seen this digital clock with weather on most Nexus One's and I simply cannot find it. Is it on a stock Nexus or is it an app?
I must admit that I was a bit jealous when i saw that most of you had cool looking home screens. So I tried to look for something girly just to decorate mine. I ended up getting a horsie background which I think is sweet. :D And I organised my apps into little folders with the help with an App organiser application too. I think mine's more of a functional sort. :rolleyes:
But sorry guys, I have no idea how to make my pictures bigger, but you can click to expand.
0jhVTK9fdIZls5SawyVFJg
Not a big changes. Just flash to CM 5.0.7-N1-Test1. So Far So Good ;)
If you like to try CM 5.0.7-N1-Test1:
Index of /android/nexus/testing
Important notes:
- Not compatible with Desire Status Bar (will end up un-finish bootloop even wipe)
- You may need to uninstall the Market updates after using some Metamorph theming, or else you may facing FC after complete download apps at Market.
- Not performing well with previous Pershoot UV/OC Kernel. Pershoot already release a new kernel which working smoothly for CM 5.0.7-N1-T1.
- Pershoot Kernel for CM 5.0.7-N1-T1 Link: Kernel 2.6.33.3 ? OC-UV-BTN-AUD-RAM-NEON_FP (1.113GHZ) ? Nexus - Droid Basement
My Opinion of CM 5.0.7-N1-T1:
- Overall is smoother, at least now can use with Live Wallpaper, not that lagging as in CM 5.0.6-N1
- Still work with HelixLauncher2 v0.7 :D
- NoData toggle is working perfectly now, anytime on and off also working. No restart is required to life back the data connection.
- Mounting the SDcard is working all the times now.
- Startup is much much more faster than CM 5.0.6-N1.
* The last picture showing the "3" music player is not included in CM 5.0.7-N1-T1 ROM, just showing off how cool this player are.
What music widget its that?
Hegemony, what's the power control widget you have there? I'm using Dazzle but yours look much nicer.
I tried taking a screen shot using the SDK/ddms method, and when i open ddms, my phone doesn't show up, I have the USB debug mode option checked, and have the java JDK installed, any ideas as to what I can do? I'm running 2.2 FRF85B on my Nexus One, and have Windows 7 64 bit
It's the Switch Pro Widget. I think it cost me $0.99 or something.
Did you install the USB drivers for the phone?
Did you install the USB drivers for the phone?[/QUOTE]
Yea, I followed each step in the tutorial, it just doesn't show up
EDIT: Never mind, driver wasn't up to date
