Post Your Vibrant Screenshots!
Trying to keep things simple, but fun.
leaf
DrStainedglove, I gotta know where you got your button icons from!!
leaf
Nice layout, whats the day of the week widget you're running? Also, is that a custom LPP calendar theme? I'd love to put that on mine, since I hate the stock one. I'd also love to know how you made your widgets extend to the screen edges. Basically, everything about your screen, please :) haha.
I would also like to know what that day of the week widget is, and where you got your background too.
thanks in advance
Rooted, Nero v4.1, voodoo enabled, with LP+
Not sure if it has been answered... but what calendar app is that? Also I have a rooted X and have been trying to find the theme or app that has that text at the bottom. I downloaded the link that Drac left for Manup's Simple Text, when I try to run it to install it tho it says Make sure my SD card is mounted. Any ideas???
I have the ADW Launcher installed. Is Manup's simple text icons only for launcher pro. And if so, does the hone required to be rooted?
Here are the instructions I found for another theme similar to that one:
Before you download the theme you must install LauncherPro on your Android. It can either be download at the previously linked site or searched in the Android Marketplace.
You will also need a desktop computer to download and unzip the files before you transfer them to your Android device.
I am sure it applies to this one as well.
Reference:
Dreamlyfe Design: .Original Theme
Also here are some instructions on how to apply it...
[FONT=&quot]1) From your homescreen, long press (press and hold) any dock icon, or dock icon position if no icon is showing, until the 'Edit dock shortcut' window shows.[/FONT]
[FONT=&quot] [/FONT]
[FONT=&quot]2) Press either 'Change shortcut' or 'Change icon'. (If you pressed 'Change shortcut' choose which application you would like to use on the dock and then, on the next screen, choose 'Custom icon').[/FONT]
[FONT=&quot]3) Navigate to the icon of your choosing, select it, and it will be applied in the position you previously chose.[/FONT]
Hope that helps!!! Worked for me!
Left-most screen (first picture) is the default screen. Clockr Evolution, Beautiful Widgets, SwitchPro, BattStatt. Second screen is done with Desktop Visualizer for 2x1 icons, and the Games folder is SiMi Folder Widget. The rest is XTG-themed LauncherPro.
Running on Bionix-v 1.2.1 like a BOSS. Love this phone.
