Post your WARP
justtom
OK I WILL START.
A little dusty but here it is
Thank you kind sir.Its the XXLtheme for go launcher EX with the ying yang live wallpaper or the 4 leaf clover live wallpaper i switch it up a lot i get bored very quickly.Also useing the sense anlog small glass 4x1 clock with weather and system stats enabled. The hour and minute box also works as a invisible or hidden app icon my hour when taped opens my daily planner and the minutes open up system settings.Also when you tap the weather the forecast will come up for your area you can set the update times
Mine always save upside down. But if u go in to gallery rotate it then crop it at full size. It will save a new right side up.
What launcher are you using, and does it allow you to get rid of SprintID/MobileID?
Edit: If I would have scrolled down the page a bit I would have found out the launcher.
Does Go Launcher allow you to uninstall Sprint ID/Mobile ID, or is this part of the stock rom?
