Hi All,
I'm having an issue with my S21 (android 13).
I am using an app that gives redeemable points for the kilometers I drive with the phone faced down (FaceItDown - By Toyota).
In my old phone S8+ I had no issues, but with my S21 it frequently reports extremely low distance traveled.
I did a test using both phones on a a drive, the S8+ says 53Km, the S21 says 3Km!
I tried contacting the developer, bu go no response.
I am assuming it is a power saving measure, but have not been able to pin it down.
So far I have tried
- Switching off Power saving
- Turning off Limit apps and Home Screen
- Turning off adaptive battery
- Including FaceItDown in never sleeping apps
Any suggestions would be welcome.
I have timed the app and it seems to behave okay for durations less than 15 minutes.
Thank you,
V.
So far I have tried
Thank you,
V.
