namurt
first off, here's the official thread over at xda with regard to the widget i'm talking about:
[MOD][PORT] (4/5/2011) Power Control Widgets - xda-developers
i believe i'm correct in my assumption that this mod is cooked into das bamf remix 1.7, which i have installed. here's my problem, though. the sound toggle does not work properly. if i try to turn my phone to a vibrate mode, it doesn't work. if i go into the main settings and manually check the vibrate tickbox for call and notification vibration, then the setting sticks. but as soon as i try to use the button in the power controls widget, the box becomes unchecked when next i look.
what gives?! this is a great widget. i truly love it, but right now i'm getting my phone into vibrate mode by holding down the volume down button. it's kinda lame when i have this slick widget.
i'm about to try re-flashing the widget over top of das bamf. think this'll work?
