Help Power control with 2.2
Has anyone notice that the power control is now always matching the setting set for the GPS. If I turn on GPS via the power control use the GPS then if I go into Location and Security and turn off GPS, the power control still shows it as active??
Thanks
The widget probably just needs time to refresh. Do what you just said and turn off GPS via the settings menu, then reboot the phone or kill your home manager. When it loads back up, it will probably show the correct setting. Also just try waiting a while and see if it automatically updates itself.
From my testing it seems that if you control the GPS from Locations and Security that it does not sync at all with power control widget. Can someone confirm this is a bug?
Hate to dredge this thread up, but I've updated to the newest OTA OS and still have this issue. Presently investigating alternative power widget options on the market.
Issue solved. I downloaded Extended Controls widget from the market and it controls GPS flawlessly. If at first you don't succeed, try try again. Right?
