exclamation_mark
I'm running Azreal X 4.0 and am looking to add the power controls to the notification bar. For the life of me I can not fond the link over at XDA. Can anyone point me in he right direction?
Here you go. Keep in mind that most ROM developers that use this theme it to match their ROM. I don't know how themed Azrael is, but this mod will bring certain things back to stock (as most theming is done in just a few framework files, which this mod uses). If you search through the thread, there are several themed versions, though.
Thanks for the thread link. There are more buried in the official thread. Glad you found it on your own. I just keep things like this bookmarked
You must have a "bazillion" bookmarks!!!![]()
Yeah, I have no idea how I ever find anything. I'm not terribly organized, so that doesn't help.
hahaha!!It would be quite ironic if your bookmarks, which theoretically make things quicker and easier to find, became so vast and unorganized that finding what you needed became a long and difficult process.
hahaha!!
On my mac, (or maybe just firefox) if i type anything dealing with the name of the page in the address bar, it brings up a list underneath of all the pages ive been to with that on it.
For the Roms page on xda i type in " xda roms " or " xda kernels " for kernels. And so on and so forth lol. Thats my organization.
Ok, before i started a new thread or ran over to xda, i wanted to ask.. Is there any way to get the pull down widget 'flashlight' to light up both LEDs? On Myns, when you select the flashlight, there is only one LED that lights up. I have had a flashlight light up both before, but it would be nice if i could get a flashable zip or something to get the pull down bar to do it, cuz im used to using that particular method. Just curious if you guys knew of anything.
Thank you sir. Ill have a look at it in the morning![]()
.Worked like a charm. I flashed it without reading anything in the post... so ill read through it todayNo problem. Depending on what ROM you're on, you might already have it. Go ahead and check first.
lolWorked like a charm. I flashed it without reading anything in the post... so ill read through it todaylol
