HardCache
Member
ok so the past 2 days I've been seeing a drop off in battery life and noticed that my Voice Calls is draining my battery more than the display.
the only things that I have changed recently that I can figure would have caused this would be that I have started using panda home, and handcent.
Voice calls are using about 35%
Display is using about 26%
... and both days I made 2-3 calls that were less than 10 mins a peice.
Today I was seeing the same thing, and I made 2 calls both less than 5 mins.
I stopped pandahome about 15-20 mins ago and went back to the base homescreen, and here's what I found:
Voice calls = 24%
Display = 30%
I'm hoping that Voice calls will go down even further now, but I can't explain why PandaHome would be draning power under Voice calls. Could Handcent be doing this as well? does anyone else use these both that can give me a little incite? thanks!
Voice calls = 24%
Display = 30%
