Help Power Off button option
ulfattu
Hello,
The power off button has three option by default
1) Silent
2) Airplane Mode
3) Power off
First problem
But my A70 showing only power off option after pressing the top Power off button
Second problem
Whenever some one calls on my A70 the calling person always gets the busy information like (The number you have dialed is currently busy), but in my call log I can see the received call number
I spoke to the service provider and they informed me that if GPRS is been used then this may happen, which is not true coz this problem arised from yesterday evening. They also told me to remove the sim and insert in and then manually select the network which also didn't worked. Lastly they told me to contact the Vodafone store and agreed that its a network issue and not the handset issue.
Did anyone face this above two problem.
Regards
ulfattu
Hello,
1) Silent
2) Airplane Mode
3) Power off
First problem
Second problem
Regards
ulfattu
I exactly had these two problems.
I made a factory reset.
Do a factory reset.
Or just try to wipe dalvik cache and then try.
If this doesn't work do a factory reset.
Note: A factory reset will erase everything except contents of sd card
Thank you Varun, wiped the cache with 1tab cleaner, but still the problem exist.
Do I have to do the factory reset.
Regards
Ulfattu
Thanks Akshay, I got what you mean.
My another query is there any script to move the Dalvik cache to the SD card??
Regards
Ulfattu
Regards
Ulfattu
Yes it is there but don't use it because u will be in a big danger when u mount sd card on PC and it is not recommended if sd card is slow one
In every rom i used it was in sd card just check the updater script of rom ..maybe it is removed or not idk..but every rom made from kitchen has dalvik to sd ...
I agree with varun.none of the roms available for A70 has dalvik2sd.i did enable it and felt slow downs so reverted it.
something tells me his calls are being diverted to voicemail directly. have that looked into and lemme know.
