Glucklichste
Member
This is a minor issue, but is there any way to customize the look of the power toggle widget? Is there a truly functional on/off widget similar to the stock option, with a customizable look perhaps? Yes, a minor issue.
Any options you know of? I esp. care about GPS and Sync, true on/off switches - which has been my biggest issue, it seems most (all?) bring you to the settings vs being a true switch/toggle for GPS especially.
