Root Power Toggles on JB Warp Sequent
Gldrz1
Gotta say i love Power Toggles on the Sequent JB update you can have two rows for toggles, the only problem ive encountered is the gps toggle does not work as it should it only acts as a shortcut, not a huge deal thou but it did work fine when i was on ICS oh well what are you gonna do it seems that JB is bit more restrictive, how about you guys have you tried PT?:)
Oh yeah I've tried it I like how it actually sticks to the top and doesn't move around haven't tried GPS toggle but I let u know
Yeah I love the 2Rows b4 I updated I was reading comments about 2Rows and was like whaaat. Now I kno. :)
Yeah GPS shortcut on mine too.
Are you serious works for you? then gonna try and re install, hopefully thatll do the trick thanks
That's weird ummm Idk what u mean by shortcut it takes u to location settings screen? Mine turns on and off like it should
yeah exactly it takes me right to the location setting screen, it does not turn on and off it used to do it when i was on ICS it sucks!
in order to get the gps to toggle instead of shortcut to gps settings, you need to move power toggles to /system/app. It requires root to make this happen.
Problem solved ;)
yeah mine has been system app forever so i had no idea....that's good to know bc one day it would of caught me by surprise lol....U The Man Superr
oh i see what ur saying so how do i do that? i think titanium backup does that doesn't it?
yep long press power toggles app in titanium backup and then press convert to system app....or use root explorer to move from /data/app to /system/app folder...I'd go titanium way if you got it though
Just clarifying, if you use a root explorer make sure you put the apk in /system/app not just /system.
you guys SupeR and money15 are the freaking men!!!!! thank you guys it worked like magic cant thank you enough!!!
one last note, you will still get updates for it, and you should still install them. You do not need to copy the updates to /system/app in the future. Just having it in there gives it perms even after updates ;)
i did it with titanium backup i guess thats ok right? so ur saying once i get the updates just allow them and itll take care of it on its own am i correct?
titanium is fine (or so i hear lol). You are correct. Let them update and everything will be good
