kasperknop
Member
If you press the gprs button off the mobile network is still running in the bagground... it doesn't seem to work at all... so how can you turn the gprs off?
Yeah I figured that, so how do you turn off the mobile network? Just turn off the sync and then it will not drain battery? It will autodisable when I turn on wifi, right?Wifi / bluetooth / gps / sync / brightness
That's the order, not mobile network.
You turn off the 'mobile network'...by going into airplane mode by long pressing the power button.
Then go into the power control widget and switch on any individual radios you might want like Wifi, GPS etc
Hmmm........The (talk+data) aka Verizion or mobile network can only be turned on and off. You cannot keep the talk on and data off. You can only switch those on and off together. IN airplane mode...both 3G and talk(voice) are off.
You can switch talk off and data on using what I mentioned in the previous post. Airplane mode + Wifi on.
Hope this helps
