Yeah, not sure how much is too much really. It does sound good though and I do like a tune at work so...
I am clueless as to what the equalizer does.
But I do recall that controls set to certain shapes help make sound better.
So...what "shape" should I have my equalizer set to for best sound? I don't know what I should be listening for...
Right now I have it set to a "hill" shape...
TIA for any advice.
Looks very good and the interface is easy to use, although the EQ takes a little practice on the sliders. However, I'm facing the problem other reviewers referred to with albums being listed and played alphabetically. I've copied FLAC albums over to the music folder on the SD card, Poweramp finds these OK and renders album art fine, too. But although I can see from the track info that the track number is there, it will only play in alphabetic order.
I think I'm missing something really obvious. All pointers welcome.
I think I found a solution for you guys:
Go into settings, then under Folders/Library go to "Sorting", then for Album/Artist Songs Sorting make sure its selected as "By track number, title". For Folder Files Sorting make sure "By file number, then filename without number" is selected - or whatever preference you have.
They are both good, but I'd lean toward PowerAMP because of things like the equalizer really. Winamp offers wireless sync from your computer to phone though which is a cool feature and may be something you would want. Its users choice really.
PowerAMP is supposed to be out next week - I don't know if our trial will expire then or not. But I'd suggest checking it out while its free, and winamp, and decide for yourself![]()
It used to do this for me in the first beta but was resolved a couple of versions ago -MP3s only here. Do you have the market version? Maybe remove and re-install if you just did an upgrade last time.
Yea, I think PowerAMP is going to lose quite a few customers from making the transition into a paid app. A donation app might even be a better idea for money.
I dunno. I've tried just about all the free players out there. I haven't seen a single one I liked as much as PowerAmp. I think it's worth the money if it's a $5 app. MixZing is like $8. PowerAmp is a much better player for less money.
Downloaded from the market a few days ago, so it's not an upgrade from beta.
Wondering if this is a problem with FLAC files as it seems those with MP3 don't have an issue.
Anyone playing FLAC and not finding this a problem?
Yeah but at least there's a free version of MixZing.
There will be a free version of PowerAMP too.
