Hi, I'm reading all the guides and FAQs intending to root shortly, *Would appreciate a bit of clarification on some things.
- In the guide to rooting using un-revoked there are the prerequisite steps to do with the Hboot drivers, then the next section states you should turn on the Desire normally. After step 9 what should be done before moving to the Rooting Process?
- 'not accepting OTA updates' *- *if I don't flash a new ROM can I get updates any other way? Do I need to?
- I've seen somewhere that I should verify the integrity of any file I might flash, and check file size and (MD5) checksum is OK. *Is there a method to do this or is it obvious when I get to that stage?
- Is internal memory an issue when rooting using un-revoked? I've currently got about 12mb but could delete some stuff to increase it
- I presume there are no contstraints on what network/sim I use, I'm currently in the process or moving from Orange contract to Giffgaff which runs on O2
- Does rooting itself clear any internal memory or is it only flashing a new ROM that increases the Apps to SD card options
Many thanks for any help
