justinbrett1975
So I updated by phone to android 2.2, and am having problems putting apps to the SD card. I have used ROM Manager to set a partition, and used App 2 SD to copy the Apps over, but it always fails.
So I put a diffrent ROM on, and it does the same thing.
So I decided it was time to get a bigger SD card anyway, so while I wait for it to arrive, I thought I would ask, is there anything I should do to either my phone, or the SD card before I put it in my phone or anything I should do to prepare it so I can get apps on my SD Card.
In my root settings (I think its root then you turn phone on and press the down button), in the partition section there what should the settings be?
Also as I'm getting a 16gig card, having read bits on here by helpful posters who say I need to partition it to be 256 with a 0 swap file, as I will have more space, can I/should i increase this, and should I put a value for the swap file (what does this do?).
