Root Pretty decent overclock...I think
jasondhsd
Member
I was able to get a pretty decent overclock with Quickclock advanced. Running Milestone .604/.621 rooted.
1200mhz = 62vsel
920mhz = 54vsel
640mhz = 44vsel
360mhz = 28vsel
All vsel are lower then stock value except for 1200mhz which remains the same. System is stable as far as I can tell ran quadrant a few times and phone is fast and responsive. With default values using stress test I got 8 lag spikes in 300seconds with the values above I only got 6 lag spikes both numbers are within acceptable margins. Quadrant score is 1906. I might try to push her to 1400 with a higher vsel just to see if I could but I think the settings I have now are excellent for battery life and speed. WHat do you guys think?
I used to have pretty good luck with these settings:
