miked0602
Member
So far from all I gathered here.
This makes sense for those less inclined to perform major tasks in rooting and tweaking their prevail.
Samsung Prevail boost mobile phone
Current Stock is FA19.
If stock quick root option:Thanks to Hroark13
All stock images as well as rooted images for each update is there.
After odin root, go back to EJ06 signal stability: Thanks to The Skater 187
Throttle disable: Thanks again to The Skater 187
IPv4 script: Thanks to Kristopher5823
List of Sprint PRL's for direct download: Thanks to Capn069
Easiest way to get your MSL/SPC: Thanks to AndroHackster
EDIT: Change Proxy to 0.0.0.0 3g Speed increase: Thanks to The Skater 187
CODES Work from stock phone app only
Also need your SPC/MSL to enter settings
##3282# Data Settings
##7678# DM or USB mode
##8778# UART or USB mode
##72786# Manual Reset/Hands Free Activation
Download Mode for Odin = Hold VolDown/Camera/Power same time from phone off state
All Thanks above relate to posts made here at AndroidForums.com
I would love to think we all are the genious behind a single idea but to be honest, TEAMwork makes the difference.
Thanks alot everyone here and GUIDES AND MODS
