any backups are on sd card and when you make them you can save to pc if a problem comes about. if you didn't make any or have any then you might have to start over, not rooting, but reinstalling a rom and all apps, ect then make a backup in cwm and save to pc for this kind of problem. also make backups regularly when making changes and trying out new thins, so if a problem arises you can always restore back and be good.yes, it can't find any backups, I have just been reading about using odin to root a newer version FF19 as one click root doesn't supprot that, will I screw up everything if I go that way?
