i do.This is probably a dumb question... But.... Do you have the phone in "DOWNLOADING" mode...
it gets to the android sceen and wont load past that, it just stays thereOdin (Return phone to Stock/Factory) - Android Forums
Did you follow the instructions at that link?
Also what is it doing when you turn it on
basically the story behind what happened....
i rooted my phone.
got rid of my default launcher and used adw.
and my phone got factory reset.
it had no default launcher, so it wont boot all the way now.
ill post the steps ive taken on trying to fix it later.
sorry, but how?
i dont have "install zip from sdcard" option--Boot into recovery:
Power phone off
Hold volume up + power until you see clockworkmodrecovery
--using Vol buttons to move and camera to select:
select Install zip from sdcard
Select Choose zip from sdcard
select zeaminstaller.zip
select yes
Press back button
Select reboot now
How do your have root but no cwm?
Ok. Nm. Have you used Odin before?
If not, its super easy.
1. Install drivers to PC.
drivers
2. Download SPHM820_FE16_ROOT_CWM.zip
3. Power phone off. Hold Vol DOWN + camera + power until you see the yellow letters
4. Unzip the download from #2
5. Double click Odin
6. follow this video
Samsung Galaxy Prevail ODIN Recovery - ED13-EE14-EJ06-FA19-FE16 Stock & Rooted (HD) - YouTube
USING THE FILES IN THE ZIP FROM STEP TWO.
7. smile at your working prevail
8. Press thanks![]()
