Will come after ICS release in the next 2 weeks the dev said on XDA.
Then Asus will unblock bootloader - voiding warranty if you elect t use the tool to do so. Which I will I am sure. But root is more important right off the bat.
Haven't looked around but is there anyone working on a recovery? I'm sure this will come quickly after but didn't know if there were any developers working on a recovery
For PC ***** like me, here is what you need to do to install drivers and get root!!
-right click computer
-opens system properties and select Hardware tab
-select device manager tab
-double click the ? mark next to the Asus android devices
-select driver tab
-update driver
-when wizard opens select "no,not at this time" to bypass wizard wanting XP disk install from a specific location so you can manually choose location
-pick where you put the drivers by navigating to the provided drivers folder and pick Android directory in the drivers folder provided
-let them install
-reboot computer
-attach Asus tablet
-click the viperMod primer tool and viola...
