Root Prime rom: UPDATED 3/5/12{ADDED REBOOT,RECOVERY,AND DOWNLOAD OPTIONS TO POWER BUTTON MENU}
Davegrow
Member
BY DAVEGROW
THIS ROM IS BASED OFF OPTIMUS PRIME
USE MY ROM AT YOURE OWN RISK IM NOT RESPONSIBLE IF YOU BRICK YOURE PHONE PERIOD.
THAT BEING SAID I DECIDED TO PUT THIS OUT FOR EVERYONE ELSE. ITS A ROM I MADE FOR MYSELF BUT I FIGURED I WOULD SHARE.
HOW TO INSTALL BOOT ANIMATIONS,
ROOT TOOLBOX WILL INSTALL THEM BUT IF YOU DONT HAVE ROOT TOOLBOX YOU CAN MANUALLY ADD THEM,
INSTRUCTIONS
1.DOWNLOAD ZIP
2.UNZIP IT
3.PLACE THE ZIP FILE NAMED "BOOTANIMATION.ZIP" IN DATA/LOCAL.
4.REBOOT
BOOT ANIMATIONS,
OPTIMUS PRIME-http://db.tt/0pYtHFR9
BIONIC BLUE-http://db.tt/NszQQHzK
GREEN BIONIC-http://db.tt/UP0wA00h
RED EYE-http://db.tt/BECtVU5e
INSTALL INSTRUCTIONS,
1.DOWNLOAD
2.UNZIP
3.THE ZIP YOU FIND INSIDE THE FOLDER CAN BE FLASHED VIA CWM. SOME WILL INCLUDE A WALLPAPER FOR THAT THEME.
UOT THEMES{CUSTOM DEODEXED ROMS ONLY},
BLUE THEME-http://db.tt/G66bOBXL
BLUE AND BLACK-http://db.tt/XaQJdDua
GREEN BIONIC-http://db.tt/Z9kWfQbz
RED EYE-http://db.tt/EYURrvYk
VER-4.0
WARNING////// IF YOU FLASH ANY OF THE UOT THEMES MADE PRIOR TO 4.0 ROM YOU WILL LOOSE REBOOT,RECOVERY,AND DOWNLOAD MOD.
REBOOT RECOVERY AND DOWNLOAD ADDED
Rom link.... http://db.tt/cdRmzQ1a
VER-3.5
CHANGED THE BOOT ANIMATION
CHANGED THE WALLPAPER
CHANGED AND ADDED SOME THINGS TO THE UOT THEME
PICS-http://db.tt/HnLYwEdB
{PICS ARE INCLUDED WITH THE ROM}{OR YOU CAN DOWNLOAD THEM FIRST}
ROM LINK-http://db.tt/eSmybEmn
VER-3.0
I suggest a full wipe
THINGS ADDED,
DEODEXED ALL{THANKS TO smith058}
REMOVED CARRIER IQ{THANKS TO smith058}
INCREASED SD CARD READ SPEED TO 2048KB VIA APP{SD-BOOSTER}
APPS INSTALL TO SD CARD BY DEFAULT {SOME APPS MAY GO TO INTERNAL}
CHANGED CARRIER NAME
Completely redone entire rom from scratch its a must see.
ROM LINK-http://db.tt/AMMFDQuX
VER-1
THINGS REMOVED,
MOBILE ID
TUTORIAL WIDGETS
STOCK LAUNCHER
THINGS ADDED,
ADW LAUNCHER
DSP MANAGER
ES FILE EXPLORER
CYANOGENMOD WALLPAPERS
OVERCLOCKING KERNEL (THANKS TO BOB ZHOME)
AND SOME STUFF I FORGOT.
HOW TO INSTALL,
DOWNLOAD ROM,
UNZIP IT,
PUT BACKUP THATS INSIDE PRIME ROM FOLDER IN SDCARD/CLOCKWORKMOD/BACKUP,
DO A FULL WIPE-INCLUDING SYSTEM
THEN RESTORE FROM BACKUP
DONATIONS TO ME ARE WELCOME-MY PAYPAL EMAIL IS growjunky@gmail.com
BOB ZHOME DONATIONS-https://www.paypal.com/cgi-bin/webscr?cmd=_donations&business=BobZhome%40cheerful%2ecom&lc=US&item_name=BobZhome%20ROM%27s&currency_code=USD&bn=PP%2dDonationsBF%3abtn_donateCC_LG%2egif%3aNonHosted
ROM LINK-http://db.tt/Op0RLNyH
First of all--let me say this rom rocks! I just installed today..and I cannot believe how much faster the phone is! I am having one problem..I cannot install anything from the android market..keeps coming up with an error. "Appname could not be downloaded due to an error (-101). Any suggestions?
Clear data from the market then go to Google services framework and clear its data. Do this in settings-applications-manage applications. It will fix the problem if done right. It might take a couple of minutes to let the market open up correctly after you clear their data.make sure you reboot after clearing their data.
MD5 Mismatch
Hey, You have to read the instructions good. I kept trying to figure out why I was getting the msmatch too, but you unzip the file and either cut or copy the file with the numbers that looks like a nandroid backup file with the date and place that file in the backup folder, after I did that It worked perfectly. Good instructions, I just didn't read them completely.
First try and got it!!!! I have been studying for months before I got this Transform Ultra, I used to have LG Optimus S and was running out of space (gave it to my mom). AWESOME I am loving it and the functionality I have seen is impressive so much better. Now to test and see if the speaker phone mic works while plugged into the car stereo, It didn't from stock. Donation will arrive tomorrow when I get paid. Thanks to everyone!
PS. I am guessing to handle updates manually, so that I am not installing or updating useless apps...That is until I figure all the new apps/features out to uninstall them. Also new to forums so correct me if I mess up.
CWGinLA:cool:
Is the carrier going to make a difference down the road? Sprint vs Boost?
And google talk came up wants to verify??? I don't think I use it unless it's talk to text?
not sure about this...
one last install came up "avast! mobile securitycould not be downloaded due to error (-101)"
SORRY FOUND IT
anybody know of good call blocker instead?
