Well yeah. Metro is refereed the home network as in, metroPCs home network
Hehe thanks.. Blonde moment
Thought this was the Metro way of updated PRL. Tried it on a buds new Esteem with 3019. Did this way to update change...anyone know?![]()
thats wired thats how I changed mines *228 I just sayed roaming list and it updated
Same here...just tried *228 just now and it works...strange![]()
Have you tried *228?
I am actually on26 but want to try 25 as there mixed reviews as to what people are having better luck with. I am actually only getting a steady 1.3Mb Down
if you want to go 3025 you could try by using QPST and flash the phone with 3025.prl if you want to go into more detail let me know. although everyone seems to be good at 3026.
here is the 3025 file, i recently upload it (don't worry its safe);
3025 (1).prl
No, I know what I am doing but for some reason I had to Update QPST... had an older version. It worked so then I flash to 25, ended up getting .5Mb Down vs 1.5 on 3026 so then just returned to 3026 by *228 and now my Down is still around .5Mb. Ugh, I wanna know what's going on with the signal around here. All tests on both PRL have been in the same place. I looked in About Phone & I am in fact on 3026 again, hmmmm.
just had them reset my service. if this does not work, i am going to clear the PRL from my phone and freshly place the Linked PRL from here onto it and see if that helps.
Nope, didnt change anything... i have done around 15 tests and all are ranging from 4G Ping of 325-900ms and a Down of .25-.8 but ended up getting ONE test that had 99ms Ping and a DL of 1.3 which is around what i normally get.
Yea but I am only getting 400-700Kb Down and between 325-900ms Ping LoL that's upsetting. I think I am going to end up using the LG Update Tool to upgrade back to ZVC then Downgrade and figure it out from there.
i cant seem to get the qspt working my phone wont show up
how do u downgrade 3026 to 3025
