Root Problem accessing fastboot on G300
actomox
After having tried - and failed - to flash a custom recovery to my rooted device I was left with a signature failure which I eventually recovered from by successfully flashing the stock rom downloaded from Huawei.
I decided to re-root using superrecovery. However although I have all the correct drivers, the device is listed when I connect it to the PC, and it shows up when I type adb devices from a command window, no way can I get into fastboot in order to flash superrecovery. Fastboot on my device is enabled as is USB debugging and that is correctly recognised.
When I disconnect phone from PC, remove battery, reinsert it and then power up while holding power and DOWN volume, the device boots normally, The same happens when I start and hold power and UP volume. If I hold UP and volume and DOWN volume together at the same time as the power button it boots into the pink screen. If I then connect the device to the PC and run install-superrecovery-windows.bat I get 'waiting for device'
Any suggestions on where I am going wrong gratefully received.
actomox,
I've moved your thread over to the G300 all-things-root area for you where I suspect you'll get a few more views and replies from the root folks.
Best of luck!
actomox,
Best of luck!
Thanks - sorry I hadn't noticed this 'All things root' sub-forum and when I did I couldn't figure a way to move my message to it.
