Root Problem after flashing Velocity .3
joelshort
Member
I flashed Velocity 0.3 a while back and everything worked great. I decided to try another ROM, but then wanted to go back to Velocity. So I flashed v.03 again and it installed correctly, everything worked great until I was given the message that an update was ready. I thought that I read somewhere to just tell it to install the update and it would boot into recovery, then reboot into Velocity and the update message wouldn't come back up. After doing that, it looks like the ROM actually partially re-installed or something, and now the market won't work at all.
I'm using aloha recovery 1.2.5
Am I doing something wrong with the update?
