hi
i had problem after i upgrade the flaytouch 3 to 4e
before i update the ft3 the battery was so much low and i read it's ok to upgrade the device if AC is on .. so i put it in AC and upgrade it
now the battery fill up so fast and also show empty after 20 min of removing the charger
i will trying to calibrating the battery .. but is this will make it work normal ?
is there another solution ?
waiting the response and thanks in advance ?
