Help Problem: Barcode Scanner and Contacts on the Droid X
I installed Barcode Scanner from ZXing. It works, except when I try to create a QR Code of a Contact, right when I pick the contact, things just jump back to the screen where you do scanning where it has the horizontal thin line. I emailed ZXing and the guy wrote back that he has seen this on the Droid X and that this model doesn't allow access to contacts, basically. Has anyone else run into this? Does anyone know if there is an effort going on to fix this on the DX?
Steve
I was in contact some more with ZXing. He said there's some limitations that are in some of the phones. Sounds like Motorola would have to fix this. Here's what he said after I sent him my log, quote:
Here's the key section, and yes this is like what the other Droid X problem was:
- Hide quoted text -
09-12 15:47:02.542 30262 30262 I ShareActivity: Showing contact URI as
barcode: null
09-12 15:47:02.542 30262 30262 D AndroidRuntime: Shutting down VM
09-12 15:47:02.542 30262 30262 W dalvikvm: threadid=3: thread exiting
with uncaught exception (group=0x4001e278)
09-12 15:47:02.542 30262 30262 E AndroidRuntime: Uncaught handler:
thread main exiting due to uncaught exception
09-12 15:47:02.550 1227 7849 I foo : **********************
resuming: 1178929312
09-12 15:47:02.550 30262 30262 E AndroidRuntime:
java.lang.RuntimeException: Failure delivering result
ResultInfo{who=null, request=1, result=-1, data=Intent { (has extras)
}} to activity {com.google.zxing.client.android/com.google.zxing.client.android.share.ShareActivity}:
java.lang.NullPointerException
09-12 15:47:02.550 30262 30262 E AndroidRuntime: at
android.app.ActivityThread.deliverResults(ActivityThread.java:3391)
android.app.ActivityThread.handleSendResult(ActivityThread.java:3433)
android.app.ActivityThread.access$2900(ActivityThread.java:121)
android.app.ActivityThread$H.handleMessage(ActivityThread.java:1955)
android.os.Handler.dispatchMessage(Handler.java:99)
android.os.Looper.loop(Looper.java:130)
android.app.ActivityThread.main(ActivityThread.java:4425)
java.lang.reflect.Method.invokeNative(Native Method)
java.lang.reflect.Method.invoke(Method.java:521)
com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:860)
com.android.internal.os.ZygoteInit.main(ZygoteInit.java:618)
dalvik.system.NativeStart.main(Native Method)
09-12 15:47:02.550 30262 30262 E AndroidRuntime: Caused by:
android.content.ContentResolver.acquireProvider(ContentResolver.java:757)
android.content.ContentResolver.query(ContentResolver.java:200)
com.google.zxing.client.android.share.ShareActivity.showContactAsBarcode(Unknown
Source)
com.google.zxing.client.android.share.ShareActivity.onActivityResult(Unknown
Source)
android.app.Activity.dispatchActivityResult(Activity.java:3828)
android.app.ActivityThread.deliverResults(ActivityThread.java:3387)
09-12 15:47:02.550 30262 30262 E AndroidRuntime: ... 11 more
The data in the returned Intent was null, and it should not be. I put
in a check that will just ignore this rather than throw an exception,
but it would have to be addressed on the other end. That's what I'd
post.
End quote
After he told me that, I went on to try two other QR Contact sharing apps, both of which worked. The ZXing guy said, quote:
Yeah I suspect what's really going on is that they have a bug in the
"old-style" contact intent API. The app only uses APIs from 1.5 and
earlier now to maintain backwards compatibility.
You can try this build which uses all the newer Android 2.2 APIs,
including the new contact APIs:
BarcodeScanner-debug.apk - zxing - Barcode Scanner Froyo beta for Android - Project Hosting on Google Code
I would not be surprised if that works.
But the old APIs are not gone and need to work, so it's valid to
report that as a bug still.
End Quote
I'm not sure I totally follow that all yet, but I just want to share this for anyone else who has run into this so they don't spend as much time trying to figure it out as I did.
