HighSierra
Member
I'm trying to help a friend who is having battery problems with a Nextbook model NextP12 running Android 4.0.3. Nextbook technical support have suggested a Factory reset.
The first instruction is (with the Nextbook powered off press and hold Volume down and the power button until you see the Green Android with the 1st menu; you will incur message "Performing Upgrade Please wait").
What actually happens is that you see the green android with the red triangle with explanation symbol.
Note that the Nextbook will boot normally.
I've done extensive searches, but most of what I find talks about custom ROMs.
Can anyone shed some light on this?
BTW the battery problem is that the battery loses charge rapidly.
