Help Problem Charging Via USB
melbell
When I charge my phone via usb, and it reaches a full charge the phone and/or computer starts to freak out.
Windows makes the sounds that it makes when you connect or disconnect a device over and over again as if I'm unplugging and plugging it back in over and over.
And if I had the phone in mass storage mode it disappears from the device list and pops open the dialog asking what I want to do (open folder to view files, etc).
Everything works fine whether I'm using mass storage mode or charging mode just fine until the battery reaches 100% and then it freaks out on me.
Hi & Welcome to the Forum!
I can't say if ur USB port is faulty but there is som'n going on there that is faulty.. It could altogether be the phone but if this doesn't happen during a normal charge then its som'n with ur comp &|or the USB port...
Define "normal charge". If you mean that I click on "charging" rather than "mass storage" then it does do it. It still makes the device connected and disconnected sounds over and over again on the computer.
when other people charge via usb what happens at a full charge? Does it disconnect the mass storage mode or is this just me?
Jus u.. it jus stops(the same as it'd do with the wall charger)
I charge via my comp quite often & never seen that happen as do others...
Yeah I was gonna ask if u had another comp u could put it on; that'll tell u whether its the phone or the computer...
