tombob
At work we have an 802.1x EAP wireless network, PEAP MSCHAPV2. I have connected my Sprint Marquee running current versions of CTMod on nearly a daily basis for the past year. Recently, the security certificates for the network were updated and I can now no longer connect to wifi at work, although I can still connect to wifi just fine at home and everywhere else in the world. IT support here doesn't have a clue. I have been searching for a solution for the past several weeks, but no joy. Just wondering if anyone had any suggestions short of a hard reset, which is where I am likely headed. Thanks.
edit: should have said that I already tried the FXR wifi fix and rescue app and the Android certificate installer app, but no luck with either.
