Problem facing using android weather application.
dkal
I have Micromax A52 Android OS 2.3 mobile. Since Last two weeks I am facing my home screen time and weather widget problem. It shows time is right but weather is not shows when I click it shows "weather update failed: cannot read from server". Please help me.
there is no solution to this problem except to get a third party widget installed from google play and it works like a charm. there are lot of weather widgets available to taste as per your choice ;)
micromax should take care about these and other bugs in their pre-installed applications as there is no root from the manufacturer in this device:o:(:mad: so that buggy apps can be uninstalled. if you get rooted anyhow then might be phone become unusable in near future:confused:
but still device performance is outstanding:p;):rolleyes::D isn't it
happy android micromaxxy:)
