Root problem flashing skyraider 4.0
i downloaded with RM, added the (required) add on, installed by checking all 3 boxes (back up, wipe data, wipe dalvik cache, it flashes then when it reboots it gets stuck on the splash screen....any ideas
Don't use rom manager to flash. Rom manager seems to have a problem locating the rom after downloading and only flashes the patch.
Manually flash in clockwork. The rom may be located in the goo.gl folder. And the patch will be in the sky raider folder.
It is best practice to NEVER use ROM manager to flash ROMS.
