Help Problem Google calendar sync
Hatye
Hi,
I use Google Calendar on my computer, iPad2 and Galaxy S2. On my iPad I have added my e-Mail account by Exchange server, but on my cell I use the built-in Gmail account syncing calendars and contacts.
I have mainly 4 calendars (school, work1, work2 and private). The problem is that one of the calendars doesn't sync properly with my cell. From tomorrow there isn't any entries on my cell (on one of the calendars), but everything is on my iPad. I have tried to remove the Google account, but that is not possible since it is the Google account.
Does anyone know what I can do to sync my cell with all my Gmail calendars properly?
Everything worked out. I've deleted the calendar and added a new one. I also deleted the settings on my calendar and it was just to set it up again :)
I have only just started using the calendar function on my phone and earlier today tried to sync it with my Google account. Nothing appears in my calendar on Google though. The appointments are still on my phone and pressing the sync button doesn't bring up any error but it doesn't add anything to my Google calendar. Am I m issing something?
That should be it. Are you sure your calendar is turned on on your Google Calendar? And that your calendar event is added in the right calendar?
Not sure what you mean by turn my google calendar on? I entered some dates into the calendar on my phone then selected sync to my google account. What else should I be doing to turn it on?
