rocketmonkeys
I've been using bluetooth headsets with my Vibrant for a while with no issues. Lately (past month or so) I've had a lot of problems getting headsets to connect.
I have a few headsets - Plantronics Voyager Pro, Etycom Etyblu2, a few cheaper ones. I'm mainly using the Etyblu2 right now. Once connected the headset works fine. But if I try to connect it after having the headset off for a while, it wont connect - the headset will not connect to the phone when tapping the power button. The phone will not connect to the headset, neither by connecting to the etyblu2 entry in the bluetooth menu, or by doing a "scan devices".
I just disabled bluetooth, waited 10 minutes, and reenabled it and it reconnected right away. What the heck?
I noticed something - when the phone is working, I can press the "scan devices" button and it'll say "scanning devices", and show the devices in my house (including my laptop). When the phone is glitching, clicking on the "scan devices" button does nothing (the 'scanning devices' doesn't show) and it only shows my remembered/paired devices, but nothing else in the house. Seems like bluetooth at that moment is not functioning correctly.
Anyone have ideas why this is happening? Anyone see similar problems? I know to disable & reenable bluetooth to get it working, but I'd really like to fix this problem if I can.
Thanks!
Samsung Vibrant
Teamwhiskey Bionix-V (Froyo 2.2), stock kernel.
Thanks!
Samsung Vibrant
