floatingpoint
I've had a look around and can't find an answer to this problem, or at least not one that I fully understand!
I saved my contacts from my old handset (LG) to the SIM card. I put the SIM into my Milestone and went to contacts, went to import/export and chose Import from SIM. It showed all of my SIM contacts, and I chose Import All.
At this point, a dialogue box with a progress bar comes up as it imports all of my contacts. However, when it's finished, they don't appear in my contacts list. It's set to display contacts with numbers.
I bluetoothed the .vcf file from my old handset to my MacBook and then from there to the Milestone, and chose Import from SD Card, but I just get the same result.
Frustrating! Any ideas?
Thanks,
Kev
Update: I've just discovered that, bizarrely, my contacts seem to appear when I type the name into the recipient box while texting... but still not in the contacts list, meaning I can't call them... and come to think of it, receiving texts from people who should be on my contacts, their name shows up. wtf?
Thanks,
Kev
