Root Problem in JC6 Firmware.. Help needed..
dakodon
I upgraded from 1.5 Cupcake to latest firmware 1.6 Donut. I noticed that battery life has decreased to half. In Sparepart's Battery History, Other Usage and Partial wake usage are normal but in Network Usage there is a item named "0" (Zero) which always is 100%. Even it cant be opened else it would force close the application (process com.android.settings).
How to rectify this program or else stop it?
One more small thing to ask. I cant find "Enter" key in Android keyboard.
I don't know for sure, but is this like Windows "Idle Process"? It's showing time not in use, rather than usage?
Thats what he is talkign about (the red zero thingie) is kinda normal on donut. I had this on all Donut Versions and still have it. But its just a bug which you can ignore.
The real problem is, that you most likey got hit by the so called "no sleep bug"
Search for it on the i7500 forum.
Did you do factory reset after upgrade?
Galaxo or vanilla upgrade?
I did factory reset before upgrade.. I jus updated the firmware to JC6 and not to Galaxo or Vanilla upgrade.. Also i restored the applications and data by using MyBackup Application..
I had the same issue and I don't remember how I solved it...
I think the '0' app was the market, hope this helps...
