Theres an app Flip Case Control that does it :thumbup:
good luck :thumbup: maybe try some coding instead of being tied to Tasker's limitationsThe status of the Proximity Sensor is available as a context via: state / sensor / proximity sensor.
If you need to access state of proximity sensor within a task (rather than as profile context), here's how. Two steps:
Step 1 - create a profile... let's call it proxprofile...with the single context of proximity sensor (*) and the action "stop". The profile itself does nothing, but will be useful in combination with step 2.
Step 2 - In your task, simply check if the profile is active (i.e. check if %PACTIVE ~ *proxprofile*) ... that is equivalent to testing the status of the proximity sensor.
* I say this for simplicity. It would be more energy efficient to combine the context proximity sensor with other lower-power contexts if it is possible and fits with your logic.
By the way, there is a forum here on AndroidForums for Tasker... you'll probably do better posting this type of question over there than in the general Applications forum
